ok so I put an new timing belt on it an it is in correct mechanical timing but the same problem going but know I can I hear my bov going off but barely z1 said check do a post leak test an check the tp sensor but I did check the tp an it has three prong sensor the connector has 2 so do you guys think that could be the cause ive had the car 7 years an put maybe 5-7 thousand miles on it b4 the na engine blew up an that was 6 years ago an I love this car an all the advice an tips are much appreciated
